Ir para o conteúdo principal
Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement
O que você precisa
  1. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: passo 1, imagem 2 %32
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Keyboard: passo 2, imagem 1 %32
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: passo 3, imagem 1 %32
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: passo 4, imagem 1 %32
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Optical Disc Drive: passo 5, imagem 1 %32
    • Use the screwdiver and the Phillips PH00 to unscrew the three, 4mm screws for the RAM compartment
  6. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: passo 6, imagem 2 %32
    • Use the Phillips PH00 to remove the 4mm screw that holds the ODD.
    • Slide the ODD outward.
  7. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: passo 7, imagem 1 %32
    • Remove the two 4mm screws and the plate attached to the ODD.
Conclusão
Equipe
USF Tampa, Team 2-5, Sullivan Fall 2016 Membro de USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 363
