Ir para o conteúdo principal
Toshiba Satellite L755D-S5150 Battery Removal
  1. Toshiba Satellite L755D-S5150 Battery Removal, Battery: passo 1, imagem 1 %32 Toshiba Satellite L755D-S5150 Battery Removal, Battery: passo 1, imagem 2 %32
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
Conclusão
Kyler Clonts
Membro desde: 10/06/16
258 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-5, Sullivan Fall 2016 Membro de USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Membros
Autoria de 5 guias
Um comentário
I've got a trouble when I try to charge the battery, when I plug in the power supply charger at the laptop it is lit led one and three in the front panel, that is OK, but after a few seconds all leds blinking and the charge is breaking on the screen appear no battery plug in. I replaced the battery pack for a new one, but the trouble continuos……
Iván Andrade - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 247
