Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If your Toshiba Satellite L755-S5244 disk drive is not reading disks, then it should be replaced. The removal of or the replacement of the disk drive will require this guide.
O que você precisa
Begin by unscrewing the screw located underneath the battery.
Then, unsnap and remove the bar above the keyboard.
Remove the seven 4mm Phillips #0 screws beneath the keyboard.
After the screws are removed, remove the face plate to reveal the motherboard.
