Introdução
If you are trying to access the fan or the screen, this guide will show you how to remove the top house casing so that you can access these parts.
O que você precisa
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
Slide the hard drive to the left, using the silver tab.
Pull up the silver tab, removing the hard drive from the slot.
Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
Remove the following screws with a Phillips #1 screwdriver.
Seventeen 5mm screws (recessed)
Three 2mm screws in the battery bay (flush-mounted)
Single 5mm screw does not need removal unless working on the screen
