Ir para o conteúdo principal
Toshiba Satellite L675D-S7016 Disk Drive Replacement
O que você precisa
  1. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Back Panel Removal: passo 1, imagem 1 %32
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  2. Toshiba Satellite L675D-S7016 Disk Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite L675D-S7016 Disk Drive Replacement: passo 2, imagem 2 %32
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  3. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Disk Drive: passo 3, imagem 1 %32
    • Remove the single 5mm Phillips #1 screw using the screwdriver.
  4. Toshiba Satellite L675D-S7016 Disk Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite L675D-S7016 Disk Drive Replacement: passo 4, imagem 2 %32
    • Push the exposed portion of the Disk Drive outwards.
    • The Disk Drive will begin sliding out of its slot. Remove Disk Drive from the laptop by hand.
  5. Toshiba Satellite L675D-S7016 Disk Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite L675D-S7016 Disk Drive Replacement: passo 5, imagem 2 %32
    • This step is only necessary if there is a disc stuck inside the drive! If you are replacing the drive and do not need to remove a disc, this can be skipped.
    • On the front of the Disk Drive, below the eject button, insert a pin or paperclip into the hole.
    • Push the pin into hole until the Disk Drive pops out.
Conclusão
Uma outra pessoa concluiu este guia.
Austin Bons
Membro desde: 09/22/16
1.131 Reputação
Autoria de 8 guias
Equipe
UC Davis, Team 2-2, Oliver Fall 2016 Membro de UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 20
Ao todo: 386
