Ir para o conteúdo principal
Toshiba Satellite L675D-S7015 Disk Drive Replacement
O que você precisa
  1. Toshiba Satellite L675D-S7015 Disk Drive Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop on a scratch free surface, exposing underneath the laptop.
    • Identify the unlocking latches denoted by the red circles.
  2. Toshiba Satellite L675D-S7015 Disk Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite L675D-S7015 Disk Drive Replacement: passo 2, imagem 2 %32
    • Simply slide the latches outward to the unlocked position.
    • The latches should stay in the unlocked position. If not, hold them in the unlocked position.
    • With the latches in the unlocked position, slide the battery out, away from the laptop.
  3. Toshiba Satellite L675D-S7015 Disk Drive Replacement, Disk Drive: passo 3, imagem 1 %32 Toshiba Satellite L675D-S7015 Disk Drive Replacement, Disk Drive: passo 3, imagem 2 %32
    • Remove the the screw shown by the red circle.
    • Lift and remove the panel shown.
  4. Toshiba Satellite L675D-S7015 Disk Drive Replacement: passo 4, imagem 1 %32
    • Remove the screw shown by the red circle.
    • Locate the small square that shows the back edge of the disk drive.
    • Push the drive in the direction shown until it cannot be pushed any further.
  5. Toshiba Satellite L675D-S7015 Disk Drive Replacement: passo 5, imagem 1 %32
    • Pull the now revealed part of the disk drive in the direction shown until the disk drive is released.
Conclusão
Jared Smith
Membro desde: 03/24/19
231 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 134
