Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide replaces the RAM in your laptop and is fairly simple to complete.
  1. Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop. Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  4. Push the two tabs outwards, away from the RAM. The RAM should spring up. Push the two tabs outwards, away from the RAM. The RAM should spring up. Push the two tabs outwards, away from the RAM. The RAM should spring up.
    • Push the two tabs outwards, away from the RAM. The RAM should spring up.
  5. Pull the top RAM stick out gently. Repeat steps 3 and 4 for the bottom RAM stick. When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
    • Pull the top RAM stick out gently.
    • Repeat steps 3 and 4 for the bottom RAM stick.
    • When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
Conclusão
8 outras pessoas concluíram este guia.
Jerry Wakai
Membro desde: 31-01-2013
335 Reputação
4 Guias de autoria
equipe
Cal Poly, Team 7-7, Maness Winter 2013 Membro de Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Membros
6 Guias de autoria
Thank-You! So Much!
Sandra Crockett - Responder
Awesome & Simple! Thank-you! My Model is a Satellite P105-S6147 1GBX2 DDR2-666 Sodimm 2BG Total.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 3,273
