Ir para o conteúdo principal
Toshiba Satellite L655D-S5095 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 2, imagem 1 %32
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 5, imagem 2 %32
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 6, imagem 1 %32
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Keyboard Replacement: passo 7, imagem 1 %32
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
Conclusão
5 outras pessoas executaram este guia.
Jerry Wakai
Membro desde: 01/31/13
377 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 7-7, Maness Winter 2013 Membro de Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
Membros da 5
Autoria de 6 guias
2 comentários
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Christopher Tidwell - Responder
Ditto on all of it. I think I broke my ZIF connector !! Help!! 😔
salirizz67@gmail.com -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 4,909
