Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Using a plastic opening tool, remove the four plastic stickers located on the four corners of the LCD screen assembly. These plastic stickers are covering screws.
Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side.
With a plastic soft pry tool, open up the laptop display assembly by methodically prying from left to right. Be careful to not damage any internal circuitry.
Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable.
Carefully disconnect the camera board from the laptop. We used tweezers.
Uma outra pessoa concluiu este guia.
