Ir para o conteúdo principal
Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement
O que você precisa
  1. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: passo 1, imagem 1 %32 Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: passo 1, imagem 2 %32
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: passo 2, imagem 1 %32
    • Remove the panel, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: passo 3, imagem 1 %32
    • Unscrew the 3.9 mm screw located at the bottom right of the panel.
  4. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to pry the CD drive out of the casing.
  5. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: passo 5, imagem 1 %32
    • Once the CD drive is out far enough to grip, pull the CD drive out to the right.
Conclusão
Uma outra pessoa concluiu este guia.
Torey
Membro desde: 01/31/13
210 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-7, Maness Winter 2013 Membro de Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Membros
6 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 2,154
