Introdução
This guide will help you replace your CD drive if you've determined that it is no longer working.
Ferramentas
Peças
Nenhum componente especificado.
Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
Uma outra pessoa concluiu este guia.
