Ir para o conteúdo principal
Toshiba Satellite L55t-B5271 Screen Replacement
O que você precisa
  1. Toshiba Satellite L55t-B5271 Screen Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L55t-B5271 Screen Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite L55t-B5271 Screen Replacement, Battery: passo 1, imagem 3 %32
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Screen Replacement: passo 2, imagem 1 %32 Toshiba Satellite L55t-B5271 Screen Replacement: passo 2, imagem 2 %32
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Screen Replacement: passo 3, imagem 1 %32 Toshiba Satellite L55t-B5271 Screen Replacement: passo 3, imagem 2 %32 Toshiba Satellite L55t-B5271 Screen Replacement: passo 3, imagem 3 %32
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: passo 4, imagem 1 %32 Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: passo 4, imagem 2 %32 Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Screen Replacement, Screen: passo 5, imagem 1 %32 Toshiba Satellite L55t-B5271 Screen Replacement, Screen: passo 5, imagem 2 %32 Toshiba Satellite L55t-B5271 Screen Replacement, Screen: passo 5, imagem 3 %32
    • Unscrew the four 6mm screws from each of the laptop hinges using a Philips head #00 screwdriver.
  6. Toshiba Satellite L55t-B5271 Screen Replacement: passo 6, imagem 1 %32 Toshiba Satellite L55t-B5271 Screen Replacement: passo 6, imagem 2 %32 Toshiba Satellite L55t-B5271 Screen Replacement: passo 6, imagem 3 %32
    • Disconnect connect the ribbon marked in red.
    • Disconnect all ribbons and cables marked in orange.
  7. Toshiba Satellite L55t-B5271 Screen Replacement: passo 7, imagem 1 %32
    • Flip your laptop back to the front.
    • Lift up the screen cover.
  8. Toshiba Satellite L55t-B5271 Screen Replacement: passo 8, imagem 1 %32 Toshiba Satellite L55t-B5271 Screen Replacement: passo 8, imagem 2 %32
    • Gently pull the screen to disconnect the monitor from the hinges.
  9. Toshiba Satellite L55t-B5271 Screen Replacement: passo 9, imagem 1 %32 Toshiba Satellite L55t-B5271 Screen Replacement: passo 9, imagem 2 %32 Toshiba Satellite L55t-B5271 Screen Replacement: passo 9, imagem 3 %32
    • Use the plastic opening tool to pry the plastic covering off of the monitor.
    • Be careful not to break the glass, as this can cause injury.
  10. Toshiba Satellite L55t-B5271 Screen Replacement: passo 10, imagem 1 %32 Toshiba Satellite L55t-B5271 Screen Replacement: passo 10, imagem 2 %32 Toshiba Satellite L55t-B5271 Screen Replacement: passo 10, imagem 3 %32
    • Remove the four 3mm Phillips head screws with a Phillips #00 screwdriver.
    • Gently remove the screen from the device.
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 1,483
