Ir para o conteúdo principal
Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink
O que você precisa
  1. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: passo 1, imagem 1 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: passo 1, imagem 2 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: passo 1, imagem 3 %32
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: passo 2, imagem 1 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: passo 2, imagem 2 %32
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: passo 3, imagem 1 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: passo 3, imagem 2 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: passo 3, imagem 3 %32
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: passo 4, imagem 1 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: passo 4, imagem 2 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: passo 5, imagem 1 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: passo 5, imagem 2 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: passo 5, imagem 3 %32
    • The ribbon and wire must be moved out of the way of the fan.
    • Using a black tweezer tool, lift the tab holding the ribbon in place and then gently pull it out.
    • Using the same tweezer tool, again lift the tab holding the wires in place and gently pull them out.
  6. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: passo 6, imagem 1 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: passo 6, imagem 2 %32
    • Unscrew the two 3mm Phillips head screws on each fan using the Phillips #00 screwdriver.
  7. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: passo 7, imagem 1 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: passo 7, imagem 2 %32 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: passo 7, imagem 3 %32
    • Unscrew the four, 3mm Phillips head screws holding the last piece to the laptop using a Phillips #00 screwdriver.
    • Gently pull the cooling fan with heat sink off the laptop and set aside.
Conclusão
Noelle Dulude
Membro desde: 03/19/18
480 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S3-G3, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G3, Peak Spring 2018
UMASSD-PEAK-S18S3G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 544
