Introdução
This guide will help you replace a faulty CD drive in your laptop. It will instruct you to remove the back cover of the laptop in order to access the CD drive. You must then unscrew the drive and replace it with the new drive
O que você precisa
Ferramenta utilizada nesse passo:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
