Ir para o conteúdo principal
Toshiba Satellite L505D-GS6000 Screen Replacement
O que você precisa
  1. Toshiba Satellite L505D-GS6000 Screen Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L505D-GS6000 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Screen Replacement: passo 2, imagem 1 %32
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Screen Replacement, Screen: passo 3, imagem 1 %32 Toshiba Satellite L505D-GS6000 Screen Replacement, Screen: passo 3, imagem 2 %32 Toshiba Satellite L505D-GS6000 Screen Replacement, Screen: passo 3, imagem 3 %32
    • Ensure that the battery has been removed and any wires are disconnected.
    • Open to a front facing position.
    • Remove screw coverings from casing.
    • Remove the M2 5x6 mm screws that under the screw covers that you removed using a Phillips #0 screwdriver.
    • Keep screws and covers together in a pile for easier reassembly.
  4. Toshiba Satellite L505D-GS6000 Screen Replacement: passo 4, imagem 1 %32 Toshiba Satellite L505D-GS6000 Screen Replacement: passo 4, imagem 2 %32 Toshiba Satellite L505D-GS6000 Screen Replacement: passo 4, imagem 3 %32
    • Carefully pry the screen covering out of place to remove it and set it to the side.
    • It may be helpful to use a plastic opening tool to assist in removal of the screen cover.
  5. Toshiba Satellite L505D-GS6000 Screen Replacement: passo 5, imagem 1 %32 Toshiba Satellite L505D-GS6000 Screen Replacement: passo 5, imagem 2 %32 Toshiba Satellite L505D-GS6000 Screen Replacement: passo 5, imagem 3 %32
    • Remove the three M2 5x6 mm screws on each side holding the screen in place, using the Phillips #0 screwdriver.
    • Gently rest the screen on the keyboard, making sure not to damage any of the wires attached to it.
  6. Toshiba Satellite L505D-GS6000 Screen Replacement: passo 6, imagem 1 %32 Toshiba Satellite L505D-GS6000 Screen Replacement: passo 6, imagem 2 %32
    • Disconnect wire at the base of the screen from the laptop.
    • Be very gentle as to not damage any electrical components of the computer.
  7. Toshiba Satellite L505D-GS6000 Screen Replacement: passo 7, imagem 1 %32 Toshiba Satellite L505D-GS6000 Screen Replacement: passo 7, imagem 2 %32 Toshiba Satellite L505D-GS6000 Screen Replacement: passo 7, imagem 3 %32
    • Peel back adhesive from the second connection to the screen and unplug the connection.
    • Remove secondary adhesive from the screen connection at the base of the screen.
    • Be cautious when removing the tape, as it will be reused for the replacement screen, so be sure not to rip it.
    • The screen is now free to be removed from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Sean Hennedy
Membro desde: 03/20/18
124 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 729
