Introdução
This guide is to be used if your disk drive is not operational and needs to be replaced.
You should replace your disk drive if it isn’t able to read something and you tried other methods of fixing it, or if the disk drive itself won’t open.
The process is fairly simple and will only require removal of one screw.
Peças
Não são necessárias peças.
  1. Shut down the computer and disconnect all cables. Flip the computer over so that the bottom is facing up.
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Push and hold the left-most switch in the leftward position.
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • You do not need to remove anything else in order to take out the disk drive.
  5. Gently slide the disk drive out to the right until it is removed from the computer.
    • Gently slide the disk drive out to the right until it is removed from the computer.
    • If the disk drive doesn’t easily slide out then there is possible damage on the inside of the laptop.
Conclusão
Adam Dellicker
461 reputação
4 Guides authored
Equipe
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 62
