Ir para o conteúdo principal
Toshiba Satellite L505 Laptop Power Jack Replacement
O que você precisa
  1. Toshiba Satellite L505 Laptop Power Jack Replacement, Keyboard: passo 1, imagem 1 %32 Toshiba Satellite L505 Laptop Power Jack Replacement, Keyboard: passo 1, imagem 2 %32 Toshiba Satellite L505 Laptop Power Jack Replacement, Keyboard: passo 1, imagem 3 %32
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Power Jack Replacement: passo 2, imagem 1 %32 Toshiba Satellite L505 Laptop Power Jack Replacement: passo 2, imagem 2 %32
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Power Jack Replacement: passo 3, imagem 1 %32 Toshiba Satellite L505 Laptop Power Jack Replacement: passo 3, imagem 2 %32
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Power Jack Replacement: passo 4, imagem 1 %32 Toshiba Satellite L505 Laptop Power Jack Replacement: passo 4, imagem 2 %32 Toshiba Satellite L505 Laptop Power Jack Replacement: passo 4, imagem 3 %32
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
  5. Toshiba Satellite L505 Laptop Power Jack Replacement, Optical Drive: passo 5, imagem 1 %32 Toshiba Satellite L505 Laptop Power Jack Replacement, Optical Drive: passo 5, imagem 2 %32
    • Turn the laptop upside down.
    • Remove the screw labeled F4 using the Phillips #1 screwdriver.
    • There are 2 screws labeled F4, the correct screw is the one closer to the hard drive.
  6. Toshiba Satellite L505 Laptop Power Jack Replacement: passo 6, imagem 1 %32 Toshiba Satellite L505 Laptop Power Jack Replacement: passo 6, imagem 2 %32
    • Gently slide the optical drive out of the device.
  7. Toshiba Satellite L505 Laptop Power Jack Replacement, Battery: passo 7, imagem 1 %32
    • Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
    • Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
  8. Toshiba Satellite L505 Laptop Power Jack Replacement, Palm Rest Assembly: passo 8, imagem 1 %32 Toshiba Satellite L505 Laptop Power Jack Replacement, Palm Rest Assembly: passo 8, imagem 2 %32 Toshiba Satellite L505 Laptop Power Jack Replacement, Palm Rest Assembly: passo 8, imagem 3 %32
    • Unscrew all of the screws marked on the underside of the laptop.
    • Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver.
    • Remove the three flat screws in the port where the Optical drive is housed in.
  9. Toshiba Satellite L505 Laptop Power Jack Replacement: passo 9, imagem 1 %32 Toshiba Satellite L505 Laptop Power Jack Replacement: passo 9, imagem 2 %32
    • Remove the keyboard and once that has been done, remove the screw marked "16."
    • Disconnect all of the cables with a blue circle.
  10. Toshiba Satellite L505 Laptop Power Jack Replacement: passo 10, imagem 1 %32 Toshiba Satellite L505 Laptop Power Jack Replacement: passo 10, imagem 2 %32 Toshiba Satellite L505 Laptop Power Jack Replacement: passo 10, imagem 3 %32
    • Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off.
  11. Toshiba Satellite L505 Laptop Power Jack Replacement, Power Jack: passo 11, imagem 1 %32 Toshiba Satellite L505 Laptop Power Jack Replacement, Power Jack: passo 11, imagem 2 %32
    • Once the motherboard is exposed, gently unplug the power cord from the motherboard.
  12. Toshiba Satellite L505 Laptop Power Jack Replacement: passo 12, imagem 1 %32
    • Follow the cable to the power jack port and carefully lift up to remove it from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 939
