Ir para o conteúdo principal
Toshiba Satellite L505 Laptop Keyboard Replacement
O que você precisa
  1. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite L505 Laptop Keyboard Replacement: passo 2, imagem 2 %32
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite L505 Laptop Keyboard Replacement: passo 3, imagem 2 %32
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite L505 Laptop Keyboard Replacement: passo 4, imagem 2 %32 Toshiba Satellite L505 Laptop Keyboard Replacement: passo 4, imagem 3 %32
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 17
Duração total: 1,229
