Ir para o conteúdo principal
Toshiba Satellite L455D-S5976 CPU Replacement
O que você precisa
  1. Toshiba Satellite L455D-S5976 CPU Replacement, Battery: passo 1, imagem 1 %32
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 CPU Replacement: passo 2, imagem 1 %32
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 CPU Replacement: passo 3, imagem 1 %32
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 CPU Replacement, Optical Drive: passo 4, imagem 1 %32
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 CPU Replacement: passo 5, imagem 1 %32
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 CPU Replacement: passo 6, imagem 1 %32
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 CPU Replacement: passo 7, imagem 1 %32
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 CPU Replacement: passo 8, imagem 1 %32
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 CPU Replacement: passo 9, imagem 1 %32 Toshiba Satellite L455D-S5976 CPU Replacement: passo 9, imagem 2 %32
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 CPU Replacement: passo 10, imagem 1 %32 Toshiba Satellite L455D-S5976 CPU Replacement: passo 10, imagem 2 %32 Toshiba Satellite L455D-S5976 CPU Replacement: passo 10, imagem 3 %32
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 CPU Replacement: passo 11, imagem 1 %32
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 CPU Replacement: passo 12, imagem 1 %32
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 CPU Replacement: passo 13, imagem 1 %32
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 CPU Replacement: passo 14, imagem 1 %32 Toshiba Satellite L455D-S5976 CPU Replacement: passo 14, imagem 2 %32 Toshiba Satellite L455D-S5976 CPU Replacement: passo 14, imagem 3 %32
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 CPU Replacement: passo 15, imagem 1 %32
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 CPU Replacement: passo 16, imagem 1 %32
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
  17. Toshiba Satellite L455D-S5976 CPU Replacement, CPU: passo 17, imagem 1 %32
    • Remove the two Phillips #1 3mm screws from the fan using a Phillips #1 screwdriver.
  18. Toshiba Satellite L455D-S5976 CPU Replacement: passo 18, imagem 1 %32
    • Remove the two cables from the fan.
  19. Toshiba Satellite L455D-S5976 CPU Replacement: passo 19, imagem 1 %32 Toshiba Satellite L455D-S5976 CPU Replacement: passo 19, imagem 2 %32
    • LIft up on the fan and remove it from the computer.
  20. Toshiba Satellite L455D-S5976 CPU Replacement: passo 20, imagem 1 %32
    • Remove the six 6mm screws from the motherboard with a #1 phillips screwdriver.
  21. Toshiba Satellite L455D-S5976 CPU Replacement: passo 21, imagem 1 %32
    • Remove the lone 10mm screw from the motherboard with a phillips #1 screwdriver.
  22. Toshiba Satellite L455D-S5976 CPU Replacement: passo 22, imagem 1 %32 Toshiba Satellite L455D-S5976 CPU Replacement: passo 22, imagem 2 %32
    • Remove the motherboard with your hands by carefully lifting up and pulling out.
  23. Toshiba Satellite L455D-S5976 CPU Replacement: passo 23, imagem 1 %32 Toshiba Satellite L455D-S5976 CPU Replacement: passo 23, imagem 2 %32
    • Remove the four Phillips #1 6mm single coil pickup screws from the cooling unit and remove the cooling unit.
  24. Toshiba Satellite L455D-S5976 CPU Replacement: passo 24, imagem 1 %32 Toshiba Satellite L455D-S5976 CPU Replacement: passo 24, imagem 2 %32
    • Using a flathead screwdriver, undo the lock on the CPU with a half turn in the counterclockwise direction.
    • Remove the CPU by lifting up on the chip.
Conclusão
11 outras pessoas executaram este guia.
NateJohnson
Membro desde: 01/26/14
1.047 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 9-26, Maness Winter 2014 Membro de Cal Poly, Team 9-26, Maness Winter 2014
CPSU-MANESS-W14S9G26
Membros da 4
Autoria de 5 guias
Um comentário
Just be vary careful with unplugging any connectors. one false step and you could wind up with some more problems.
harh027213 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 3,826
