Ir para o conteúdo principal
Toshiba Satellite L455-S5975 WiFi Card Replacement
O que você precisa
  1. Toshiba Satellite L455-S5975 WiFi Card Replacement, WiFi Card: passo 1, imagem 1 %32
    • Flip Laptop into an upside-down position.
    • Push latches (indicated in red) outward.
    • Lift battery by notch (indicated in green) to remove.
  2. Toshiba Satellite L455-S5975 WiFi Card Replacement: passo 2, imagem 1 %32 Toshiba Satellite L455-S5975 WiFi Card Replacement: passo 2, imagem 2 %32
    • Remove the plastic cover closest to the battery by first unscrewing the single 7mm screw (in red) with the phillips #00 screwdriver.
    • Now, lift the cover by the notch under the screw (in red) using a plastic opening tool.
  3. Toshiba Satellite L455-S5975 WiFi Card Replacement: passo 3, imagem 1 %32 Toshiba Satellite L455-S5975 WiFi Card Replacement: passo 3, imagem 2 %32 Toshiba Satellite L455-S5975 WiFi Card Replacement: passo 3, imagem 3 %32
    • Locate the Wifi Card on the right-hand side of compartment you just revealed
    • Remove the black and white wire by carefully pulling them off with the plastic lever (you will hear a light snapping sound).
  4. Toshiba Satellite L455-S5975 WiFi Card Replacement: passo 4, imagem 1 %32
    • Unscrew the two 6 mm screws (indicated in red) located at the bottom of the WiFi card and store them in a safe place.
  5. Toshiba Satellite L455-S5975 WiFi Card Replacement: passo 5, imagem 1 %32 Toshiba Satellite L455-S5975 WiFi Card Replacement: passo 5, imagem 2 %32
    • Gently remove the wifi card from the laptop.
Conclusão
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
Dylan Baker
Membro desde: 03/11/14
188 Reputação
Autoria de 1 guia
Equipe
UMD team 2 Membro de UMD team 2
Community
4 Membros
1 Guia de autoria
Um comentário
are you aware of any compatible upgrades for a faster speed, like a dual band 5ghz card? from what im gathering its probably not worth the trial and error, because the antenna is designed probably for just 2.4ghz, so i'm thinking a usb dongle is the best option but wondering what your thoughts are? great guide btw
Tyler Bombara - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 10
Ao todo: 2,329
