Ir para o conteúdo principal
Toshiba Satellite L455-S5975 LCD Display Replacement
O que você precisa
  1. Toshiba Satellite L455-S5975 LCD Display Replacement, Keyboard: passo 1, imagem 1 %32 Toshiba Satellite L455-S5975 LCD Display Replacement, Keyboard: passo 1, imagem 2 %32
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 2, imagem 1 %32
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 3, imagem 1 %32
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 4, imagem 1 %32 Toshiba Satellite L455-S5975 LCD Display Replacement: passo 4, imagem 2 %32
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
  5. Toshiba Satellite L455-S5975 LCD Display Replacement, Fan: passo 5, imagem 1 %32 Toshiba Satellite L455-S5975 LCD Display Replacement, Fan: passo 5, imagem 2 %32
    • Flip the laptop over to access the battery.
    • Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
  6. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 6, imagem 1 %32
    • Remove the twelve 10mm screws with a Phillips #00 screwdriver.
    • Remove the cover over the hard drive (upper right in photo) and remove the four 10mm screws at the four corners.
  7. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 7, imagem 1 %32
    • Remove the three 4mm screws with a Phillips #00 screwdriver.
  8. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 8, imagem 1 %32
    • Flip the laptop over so it's in the right-side-up position.
    • Lift the grey plastic casing up and unhook any wires attached to the casing.
    • Remove the five 10mm screws, each with a label 'F10' next to them.
  9. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 9, imagem 1 %32 Toshiba Satellite L455-S5975 LCD Display Replacement: passo 9, imagem 2 %32
    • Disconnect the flat thin wire connecting the track pad to the motherboard by pulling it straight out.
    • Disconnect the thin red wire on the right side of the motherboard.
  10. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 10, imagem 1 %32
    • Remove the two 6mm screws with a Phillips #00 screwdriver.
  11. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 11, imagem 1 %32 Toshiba Satellite L455-S5975 LCD Display Replacement: passo 11, imagem 2 %32
    • Disconnect the red and yellow wires connecting the fan to the motherboard by pulling the wires straight out.
    • Remove the fan.
  12. Toshiba Satellite L455-S5975 LCD Display Replacement, LCD Display: passo 12, imagem 1 %32 Toshiba Satellite L455-S5975 LCD Display Replacement, LCD Display: passo 12, imagem 2 %32
    • Remove the following six screws located at the base of the monitor:
    • Three 5mm Phillip Head Screws
    • Two 6mm Phillip Head Screws
    • One 7mm Phillip Head Screw
    • Disconnect the long thing grey cable that is attached to the motherboard by pulling it out.
  13. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 13, imagem 1 %32 Toshiba Satellite L455-S5975 LCD Display Replacement: passo 13, imagem 2 %32
    • Remove 2 plastic plugs using a spudger located behind the corners of the rotating part of the LCD.
    • Remove two 5mm Phillips head screws located where the plugs used to be.
  14. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 14, imagem 1 %32
    • Remove the black and white wires connected to the LCD. The wires are located under the motherboard and can be accessed through the back panel of the computer.
    • Use a spudger to remove wires by pushing the wires upward, away from the logic board.
  15. Toshiba Satellite L455-S5975 LCD Display Replacement: passo 15, imagem 1 %32
    • Remove the LCD Screen
Conclusão
4 outras pessoas executaram este guia.
Mike Kennedy
Membro desde: 04/18/13
160 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 2-21, Maness Spring 2013 Membro de Cal Poly, Team 2-21, Maness Spring 2013
CPSU-MANESS-S13S2G21
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 3,517
