Ir para o conteúdo principal
Toshiba Satellite L455-S5975 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Keyboard Replacement: passo 3, imagem 1 %32
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite L455-S5975 Keyboard Replacement: passo 4, imagem 2 %32
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
Conclusão
Uma outra pessoa concluiu este guia.
Mike Kennedy
Membro desde: 04/18/13
160 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 2-21, Maness Spring 2013 Membro de Cal Poly, Team 2-21, Maness Spring 2013
CPSU-MANESS-S13S2G21
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 2,403
