Ir para o conteúdo principal
Toshiba Satellite L455-S5975 Fan Replacement
O que você precisa
  1. Toshiba Satellite L455-S5975 Fan Replacement, Keyboard: passo 1, imagem 1 %32 Toshiba Satellite L455-S5975 Fan Replacement, Keyboard: passo 1, imagem 2 %32
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Fan Replacement: passo 2, imagem 1 %32
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Fan Replacement: passo 3, imagem 1 %32
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite L455-S5975 Fan Replacement: passo 4, imagem 2 %32
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
  5. Toshiba Satellite L455-S5975 Fan Replacement, Fan: passo 5, imagem 1 %32 Toshiba Satellite L455-S5975 Fan Replacement, Fan: passo 5, imagem 2 %32
    • Flip the laptop over to access the battery.
    • Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
  6. Toshiba Satellite L455-S5975 Fan Replacement: passo 6, imagem 1 %32
    • Remove the twelve 10mm screws with a Phillips #00 screwdriver.
    • Remove the cover over the hard drive (upper right in photo) and remove the four 10mm screws at the four corners.
  7. Toshiba Satellite L455-S5975 Fan Replacement: passo 7, imagem 1 %32
    • Remove the three 4mm screws with a Phillips #00 screwdriver.
  8. Toshiba Satellite L455-S5975 Fan Replacement: passo 8, imagem 1 %32
    • Flip the laptop over so it's in the right-side-up position.
    • Lift the grey plastic casing up and unhook any wires attached to the casing.
    • Remove the five 10mm screws, each with a label 'F10' next to them.
  9. Toshiba Satellite L455-S5975 Fan Replacement: passo 9, imagem 1 %32 Toshiba Satellite L455-S5975 Fan Replacement: passo 9, imagem 2 %32
    • Disconnect the flat thin wire connecting the track pad to the motherboard by pulling it straight out.
    • Disconnect the thin red wire on the right side of the motherboard.
  10. Toshiba Satellite L455-S5975 Fan Replacement: passo 10, imagem 1 %32
    • Remove the two 6mm screws with a Phillips #00 screwdriver.
  11. Toshiba Satellite L455-S5975 Fan Replacement: passo 11, imagem 1 %32 Toshiba Satellite L455-S5975 Fan Replacement: passo 11, imagem 2 %32
    • Disconnect the red and yellow wires connecting the fan to the motherboard by pulling the wires straight out.
    • Remove the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Alex Brizuela
Membro desde: 04/19/13
88 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 2-21, Maness Spring 2013 Membro de Cal Poly, Team 2-21, Maness Spring 2013
CPSU-MANESS-S13S2G21
4 Membros
Autoria de 5 guias
Um comentário
I've taken my Toshiba L455 apart a few times from watching a few different You Tube videos. I WISH I would've seen THIS site & demonstration then! It makes it SO MUCH easier by actually showing each & ALL of the screws that need to come out,It tells you in GREAT detail step by step of everything you need to do so that nothing's ruined in the process! In the videos like when it comes to removing the keyboard/ribbon for it,you can't see what they're doing when removing the ribbon,which was my hardest part! I actually had it all put back together to learn it wasn't put back together right(since I wasn't exactly sure how it came off!) After 3 times,I FINALLY figured it out,by myself! So even this 1 doesn't say that the white clip that comes out 2 release the ribbon goes back UNDER the ribbon when putting it back! Cuz mine came out fast so I missed how it was even in there. Hopefully this helps someone since I SO wished I had this! Lol!
pds252 - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 3,014
