Ir para o conteúdo principal
Toshiba Satellite L455-S5046 The Fan Replacement
O que você precisa
  1. Toshiba Satellite L455-S5046 The Fan Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L455-S5046 The Fan Replacement, Battery: passo 1, imagem 2 %32
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 The Fan Replacement, Fan: passo 2, imagem 1 %32
    • Start on the back and unscrew the 12 Phillips #0 11-mm screws holding the back cover down.
  3. Toshiba Satellite L455-S5046 The Fan Replacement: passo 3, imagem 1 %32
    • Pop off the hard drive cover, and then unscrew the four 11-mm Phillips #0 screws.
  4. Toshiba Satellite L455-S5046 The Fan Replacement: passo 4, imagem 1 %32 Toshiba Satellite L455-S5046 The Fan Replacement: passo 4, imagem 2 %32
    • Flip the laptop over. Remove the keyboard as instructed in the keyboard replacement guide.
    • Gently remove the connector visible in the upper right hand corner of the laptop by pulling to the right.
    • Remove the cover slowly. There will be two other connectors on the underside that can be removed by pulling gently.
  5. Toshiba Satellite L455-S5046 The Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite L455-S5046 The Fan Replacement: passo 5, imagem 2 %32
    • Remove the connector between the fan and the laptop by pulling gently to the left.
    • Remove the two indicated 11-mm Phillips #0 screws.
  6. Toshiba Satellite L455-S5046 The Fan Replacement: passo 6, imagem 1 %32
    • Now gently lift the fan and pull out.
Conclusão
Daryl Spurgeon
Membro desde: 01/10/17
610 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 291
