Ir para o conteúdo principal
Toshiba Satellite L455-S5046 Optical Drive Replacement
O que você precisa
Vídeo de Apresentação
  1. Toshiba Satellite L455-S5046 Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Unscrew 1 Phillips #0 7-mm screw on the back of the computer.
  2. Toshiba Satellite L455-S5046 Optical Drive Replacement: passo 2, imagem 1 %32
    • Lift the plate and gently pull it away from yourself, until it is removed.
  3. Toshiba Satellite L455-S5046 Optical Drive Replacement: passo 3, imagem 1 %32
    • Unscrew the 1 Phillips #0 7-mm screw, located on the right side where the silver tabs of the optical drive poke out.
  4. Toshiba Satellite L455-S5046 Optical Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite L455-S5046 Optical Drive Replacement: passo 4, imagem 2 %32
    • The optical drive is partially visible and push it to the right.
    • The optical drive should pop out on the right side, and you can gently pull it out.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 201
