Ir para o conteúdo principal
Toshiba Satellite L45-S7423 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 2, imagem 2 %32
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 3, imagem 2 %32
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement, Hard Drive: passo 4, imagem 3 %32
    • Remove the two Phillips screws holding the panel in place.
    • These screws cannot be removed completely from the panel. They are fastened to the panel to avoid loss.
  5. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 5, imagem 1 %32
    • To remove, lift up the panel's tab.
  6. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 6, imagem 2 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 6, imagem 3 %32
    • Remove the screws attaching the hard drive and bracket.
    • Four 4.6 mm Phillips screws.
  7. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 7, imagem 1 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 7, imagem 2 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 7, imagem 3 %32
    • Lift up the black tab to expose hard drive.
    • Grab the hard drive bracket and pull to remove.
  8. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 8, imagem 1 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 8, imagem 2 %32
    • Remove the screws attaching the hard drive to hard drive bracket.
    • Four 3.6 mm Phillips screws.
  9. Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 9, imagem 1 %32 Toshiba Satellite L45-S7423 Hard Drive Replacement: passo 9, imagem 2 %32
    • Separate the hard drive from hard drive bracket to complete removal.
Conclusão
Stephen Sippel
Membro desde: 04/16/13
194 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 21-54, Johann Spring 2013 Membro de Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,729
