Ir para o conteúdo principal
Toshiba Satellite L45-S7423 Battery Replacement
  1. Toshiba Satellite L45-S7423 Battery Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L45-S7423 Battery Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite L45-S7423 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite L45-S7423 Battery Replacement: passo 2, imagem 2 %32
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Battery Replacement: passo 3, imagem 1 %32 Toshiba Satellite L45-S7423 Battery Replacement: passo 3, imagem 2 %32
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
Conclusão
Stephen Sippel
Membro desde: 04/16/13
194 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 21-54, Johann Spring 2013 Membro de Cal Poly, Team 21-54, Johann Spring 2013
CPSU-JOHANN-S13S21G54
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 2,618
