Ir para o conteúdo principal
Toshiba Satellite L40 PSL4BE Replacement Hard Drive
O que você precisa
    • Start by power off your laptop and removing any charging adapters.
    • Then flip the laptop upside down so that the screws are right side up as shown.
    • Unscrew the following screws with a standard Philips screwdriver.
    • All screws are the same size but remember to keep track of screws as they are smaller than a standard household screw and are easy to lose.
    • Remove the highlighted panel from the laptop you can use a flat head screwdriver or your hands some light force maybe require but do not apply too much force as it may snap the panel.
    • Unscrew the highlighted screws then carefully lift the hard drive and caddy out of the slot.
    • Remember to take extra care when removing and handling as hard drives are very fragile.
    • Remove the screws on the side of the caddy and carefully slide the hard drive out from the caddy.
Conclusão
Lewis Johnston
Membro desde: 12/15/23
133 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 49
