Ir para o conteúdo principal
Toshiba Satellite L35-S2174 RAM Replacement
O que você precisa
  1. Toshiba Satellite L35-S2174 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite L35-S2174 RAM Replacement: passo 2, imagem 2 %32
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 RAM Replacement: passo 3, imagem 1 %32 Toshiba Satellite L35-S2174 RAM Replacement: passo 3, imagem 2 %32
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 RAM Replacement: passo 4, imagem 1 %32
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 RAM Replacement, RAM: passo 5, imagem 1 %32 Toshiba Satellite L35-S2174 RAM Replacement, RAM: passo 5, imagem 2 %32 Toshiba Satellite L35-S2174 RAM Replacement, RAM: passo 5, imagem 3 %32
    • Unscrew the two circled screws with a J1 screwdriver. The screws will remain attached to the panel.
    • Lift the panel and remove it from the laptop.
  6. Toshiba Satellite L35-S2174 RAM Replacement: passo 6, imagem 1 %32 Toshiba Satellite L35-S2174 RAM Replacement: passo 6, imagem 2 %32 Toshiba Satellite L35-S2174 RAM Replacement: passo 6, imagem 3 %32
    • Pull the flaps apart on either side of the RAM chip. It will pop upwards.
    • Carefully lift the RAM chip out of the computer.
Conclusão
Fiona Turick
Membro desde: 10/18/16
101 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-4, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-4, Catania Fall 2016
UMASSD-CATANIA-F16S1G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 301
