Ir para o conteúdo principal
Toshiba Satellite L305D-S5950 Motherboard Replacement
O que você precisa
  1. Toshiba Satellite L305D-S5950 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 2, imagem 2 %32
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 3, imagem 2 %32
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Motherboard Replacement, Hard Disk Drive: passo 5, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement, Hard Disk Drive: passo 5, imagem 2 %32
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 7, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 8, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 8, imagem 2 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 8, imagem 3 %32
    • To separate the hard drive from the caddy, unscrew the two screws.
  9. Toshiba Satellite L305D-S5950 Motherboard Replacement, RAM: passo 9, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement, RAM: passo 9, imagem 2 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement, RAM: passo 9, imagem 3 %32
    • Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
  10. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 10, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 10, imagem 2 %32
    • Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
  11. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 11, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 11, imagem 2 %32
    • Remove the RAM module by pulling it out at the angle it was rotated to.
  12. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 12, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 12, imagem 2 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 12, imagem 3 %32
    • If you want to replace the second RAM module, apply steps 2 and 3 to do so.
  13. Toshiba Satellite L305D-S5950 Motherboard Replacement, Keyboard: passo 13, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement, Keyboard: passo 13, imagem 2 %32
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  14. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 14, imagem 1 %32
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  15. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 15, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 15, imagem 2 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 15, imagem 3 %32
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  16. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 16, imagem 1 %32
    • Remove the keyboard completely from the laptop.
  17. Toshiba Satellite L305D-S5950 Motherboard Replacement, Motherboard Cover: passo 17, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement, Motherboard Cover: passo 17, imagem 2 %32
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  18. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 18, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 18, imagem 2 %32 Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 18, imagem 3 %32
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  19. Toshiba Satellite L305D-S5950 Motherboard Replacement, Motherboard: passo 19, imagem 1 %32
    • Unscrew all the screws indicated by the red circles (The bottom two screws are 10.75mm and the top screw is 5mm).
    • Unplug all the wires indicated by the orange squares.
    • Some wires may have a lock on them that needs to be pulled out before the wire is removed.
  20. Toshiba Satellite L305D-S5950 Motherboard Replacement: passo 20, imagem 1 %32
    • At this point the motherboard can be fully removed from the laptop.
Conclusão
7 outras pessoas executaram este guia.
William
Membro desde: 03/26/14
889 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 1-2, Benson Spring 2014 Membro de Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 2,468
