Ir para o conteúdo principal
Toshiba Satellite L305D-S5950 Motherboard Cover Replacement
O que você precisa
  1. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Battery: passo 1, imagem 1 %32
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 2, imagem 2 %32
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 3, imagem 2 %32
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Keyboard: passo 5, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Keyboard: passo 5, imagem 2 %32
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 6, imagem 1 %32
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 7, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 7, imagem 2 %32 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 7, imagem 3 %32
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 8, imagem 1 %32
    • Remove the keyboard completely from the laptop.
  9. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Motherboard Cover: passo 9, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement, Motherboard Cover: passo 9, imagem 2 %32
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  10. Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 10, imagem 1 %32 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 10, imagem 2 %32 Toshiba Satellite L305D-S5950 Motherboard Cover Replacement: passo 10, imagem 3 %32
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
Conclusão
John Drinkwater
Membro desde: 03/26/14
364 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 1-2, Benson Spring 2014 Membro de Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 316
