Ir para o conteúdo principal
Toshiba Satellite L305D-S5950 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite L305D-S5950 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305D-S5950 Keyboard Replacement: passo 2, imagem 2 %32
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305D-S5950 Keyboard Replacement: passo 3, imagem 2 %32
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Keyboard Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 Toshiba Satellite L305D-S5950 Keyboard Replacement, Keyboard: passo 5, imagem 2 %32
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 Keyboard Replacement: passo 6, imagem 1 %32
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 Keyboard Replacement: passo 7, imagem 1 %32 Toshiba Satellite L305D-S5950 Keyboard Replacement: passo 7, imagem 2 %32 Toshiba Satellite L305D-S5950 Keyboard Replacement: passo 7, imagem 3 %32
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 Keyboard Replacement: passo 8, imagem 1 %32
    • Remove the keyboard completely from the laptop.
Conclusão
William
Membro desde: 03/26/14
889 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 1-2, Benson Spring 2014 Membro de Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
Membros da 3
Autoria de 10 guias
Um comentário
I have a Toshiba Satellite L305D. A glass of tea was spilled on it several months ago and I just turned it on and it is working but some of the keys do not work, shift, letter a and several more. If I replace the keyboard will this fix this problem or are there more parts that should be replaced? Thanks, Pam
pamtinkle - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 553
