Ir para o conteúdo principal
Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement
O que você precisa
  1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Battery: passo 1, imagem 1 %32
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 2, imagem 2 %32
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 3, imagem 2 %32
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 4, imagem 1 %32
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: passo 5, imagem 1 %32 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: passo 5, imagem 2 %32
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 6, imagem 1 %32
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 7, imagem 1 %32 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 7, imagem 2 %32
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 8, imagem 1 %32 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 8, imagem 2 %32 Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: passo 8, imagem 3 %32
    • To separate the hard drive from the caddy, unscrew the two screws.
Conclusão
Ricky Baker
Membro desde: 03/26/14
217 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 1-2, Benson Spring 2014 Membro de Clemson, Team 1-2, Benson Spring 2014
CLEM-BENSON-S14S1G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 864
