Ir para o conteúdo principal
Toshiba Satellite L305D-S5900 Storage Drive Replacement
O que você precisa
  1. Toshiba Satellite L305D-S5900 Storage Drive Replacement, Storage Drive: passo 1, imagem 1 %32
    • Power off your laptop before beginning disassembly.
    • Two 5.3 mm Phillips #1 screws boxed in red are located at the top right corner on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Storage Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305D-S5900 Storage Drive Replacement: passo 2, imagem 2 %32 Toshiba Satellite L305D-S5900 Storage Drive Replacement: passo 2, imagem 3 %32
    • Remove the panel that houses the storage drive by unscrewing the two 5.3 mm Phillips #1 screws that hold it into place
  3. Toshiba Satellite L305D-S5900 Storage Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305D-S5900 Storage Drive Replacement: passo 3, imagem 2 %32
    • The standard hard disk drive that comes with this laptop model should have a ribbon attached to it. Pull this ribbon back until the hard drive comes out of the socket.
    • If your drive doesn’t have this ribbon, it can be pushed out of place by wedging a plastic opening tool in between the drive and its socket and push it out.
Conclusão
Sing Yang Cheng
Membro desde: 10/20/16
501 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 376
