Ir para o conteúdo principal
Toshiba Satellite L305D-S5900 RAM Replacement
O que você precisa
  1. Toshiba Satellite L305D-S5900 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Power off your laptop before beginning dissassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305D-S5900 RAM Replacement: passo 2, imagem 2 %32
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 RAM Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305D-S5900 RAM Replacement: passo 3, imagem 2 %32 Toshiba Satellite L305D-S5900 RAM Replacement: passo 3, imagem 3 %32
    • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
    • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
    • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
    • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
Conclusão
Sing Yang Cheng
Membro desde: 10/20/16
501 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G6
2 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 277
