Ir para o conteúdo principal
Toshiba Satellite L305D-S5895 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite L305D-S5895 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
  2. Toshiba Satellite L305D-S5895 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305D-S5895 Keyboard Replacement: passo 2, imagem 2 %32
    • Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
  3. Toshiba Satellite L305D-S5895 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305D-S5895 Keyboard Replacement: passo 3, imagem 2 %32
    • After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop.
    • Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
  4. Toshiba Satellite L305D-S5895 Keyboard Replacement: passo 4, imagem 1 %32
    • Lift the keyboard up in order to remove the cable.
  5. Toshiba Satellite L305D-S5895 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite L305D-S5895 Keyboard Replacement: passo 5, imagem 2 %32 Toshiba Satellite L305D-S5895 Keyboard Replacement: passo 5, imagem 3 %32
    • Notice the two white tabs on the compartment holding the cable.
    • Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
Conclusão
Tyler GLick
Membro desde: 10/21/16
101 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G8
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 8
Duração total: 365
