Ir para o conteúdo principal
Toshiba Satellite L305-S5955 Wireless Card Replacement
O que você precisa
  1. Toshiba Satellite L305-S5955 Wireless Card Replacement, Lock Tabs: passo 1, imagem 1 %32
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 2, imagem 1 %32
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Wireless Card Replacement, Keyboard: passo 3, imagem 1 %32
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 4, imagem 1 %32 Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 4, imagem 2 %32
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 5, imagem 1 %32
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 6, imagem 1 %32 Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 6, imagem 2 %32
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
  7. Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: passo 7, imagem 1 %32 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: passo 7, imagem 2 %32 Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: passo 7, imagem 3 %32
    • Detach white and black wires by gently pulling straight up.
  8. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 8, imagem 1 %32
    • Unscrew both 3 mm Phillips head PH1 screws and allow the wireless card to pop up.
  9. Toshiba Satellite L305-S5955 Wireless Card Replacement: passo 9, imagem 1 %32
    • Pull the card out vertically.
Conclusão
Samuel Baker
Membro desde: 01/30/17
307 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 1-2, Baechle Spring 2017 Membro de IUPUI, Team 1-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G2
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 789
