Ir para o conteúdo principal
Toshiba Satellite L305-S5955 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite L305-S5955 Keyboard Replacement, Lock Tabs: passo 1, imagem 1 %32
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Keyboard Replacement: passo 2, imagem 1 %32
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite L305-S5955 Keyboard Replacement: passo 4, imagem 2 %32
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Keyboard Replacement: passo 5, imagem 1 %32
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite L305-S5955 Keyboard Replacement: passo 6, imagem 2 %32
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
Conclusão
Chris
Membro desde: 09/30/14
1 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-2, Buehl Fall 2014 Membro de Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 960
