Ir para o conteúdo principal
Toshiba Satellite L305-S5955 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite L305-S5955 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 2, imagem 2 %32 Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 2, imagem 3 %32
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5955 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Locate the hard drive on the laptop, above the part number and serial number sticker
  4. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the two screws marked "4" from the hard drive cover
  5. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 5, imagem 1 %32
    • Pry up the cover of the hard drive compartment.
  6. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 6, imagem 2 %32
    • Slide hard drive out by pulling gently on the felt handle
  7. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 7, imagem 1 %32
    • Remove four outer black screws on the corners of the hard drive case
  8. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 8, imagem 1 %32
    • Remove hard drive from the casing by gently sliding the drive out of the case.
  9. Toshiba Satellite L305-S5955 Hard Drive Replacement: passo 9, imagem 1 %32
    • Complete these steps in reverse order to insert hard drive back into laptop.
Conclusão
Eric
Membro desde: 09/30/14
55 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-2, Buehl Fall 2014 Membro de Ohio State, Team 1-2, Buehl Fall 2014
OSU-BUEHL-F14S1G2
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,010
