Ir para o conteúdo principal
Toshiba Satellite L305-S5946 RAM Replacement
O que você precisa
  1. Toshiba Satellite L305-S5946 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside-down with the display hinges facing away from you.
  2. Toshiba Satellite L305-S5946 RAM Replacement: passo 2, imagem 1 %32
    • Slide the latch for the left battery bay to the left.
  3. Toshiba Satellite L305-S5946 RAM Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305-S5946 RAM Replacement: passo 3, imagem 2 %32 Toshiba Satellite L305-S5946 RAM Replacement: passo 3, imagem 3 %32
    • Slide the latch for the right battery bay to the right and hold.
    • Continue to hold the latch while using a plastic opening tool to lift and remove the battery bay cover.
    • Remove the battery.
  4. Toshiba Satellite L305-S5946 RAM Replacement, RAM: passo 4, imagem 1 %32
    • Using a Phillips #1 screwdriver, turn the screw on the RAM cover until you hear a click.
    • This is a captive panel screw and remains with the cover.
  5. Toshiba Satellite L305-S5946 RAM Replacement: passo 5, imagem 1 %32 Toshiba Satellite L305-S5946 RAM Replacement: passo 5, imagem 2 %32
    • Remove the RAM cover by inserting the plastic opening tool into the indent and lifting.
  6. Toshiba Satellite L305-S5946 RAM Replacement: passo 6, imagem 1 %32 Toshiba Satellite L305-S5946 RAM Replacement: passo 6, imagem 2 %32
    • Push the white and silver retaining clips away from each side of the RAM card using your fingernails.
    • The RAM card should pop up at an angle.
  7. Toshiba Satellite L305-S5946 RAM Replacement: passo 7, imagem 1 %32 Toshiba Satellite L305-S5946 RAM Replacement: passo 7, imagem 2 %32
    • Pull the RAM card away from the computer.
    • Repeat Steps 6 and 7 to remove the other RAM card that may be installed.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 3-49, Amido Spring 2013 Membro de Cal Poly, Team 3-49, Amido Spring 2013
CPSU-AMIDO-S13S3G49
Membros da 4
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 922
