Ir para o conteúdo principal
Toshiba Satellite L305-S5875 RAM Replacement
O que você precisa
  1. Toshiba Satellite L305-S5875 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305-S5875 RAM Replacement: passo 2, imagem 2 %32 Toshiba Satellite L305-S5875 RAM Replacement: passo 2, imagem 3 %32
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 RAM Replacement, RAM: passo 3, imagem 1 %32 Toshiba Satellite L305-S5875 RAM Replacement, RAM: passo 3, imagem 2 %32 Toshiba Satellite L305-S5875 RAM Replacement, RAM: passo 3, imagem 3 %32
    • Locate the RAM Module compartment on the bottom side of the laptop.
    • Carefully remove the 4.6mm 0 Phillips head screw and put it in a safe place.
    • Locate the notch on the screw side of the lid and lift to remove it.
  4. Toshiba Satellite L305-S5875 RAM Replacement: passo 4, imagem 1 %32 Toshiba Satellite L305-S5875 RAM Replacement: passo 4, imagem 2 %32 Toshiba Satellite L305-S5875 RAM Replacement: passo 4, imagem 3 %32
    • Push the metal tabs on the sides of the RAM outward and the RAM will pop up.
    • Gently pull the RAM out.
    • Replace the RAM by sliding the new one into the angled socket similarly to how you removed the old RAM.
    • Gently apply pressure until the metal tabs on the sides click into place.
Conclusão
3 outras pessoas executaram este guia.
Elliot Fiske
Membro desde: 01/30/13
36 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 20-5, Maness Winter 2013 Membro de Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 6,840
