Ir para o conteúdo principal
Toshiba Satellite L305-S5875 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite L305-S5875 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305-S5875 Keyboard Replacement: passo 2, imagem 2 %32 Toshiba Satellite L305-S5875 Keyboard Replacement: passo 2, imagem 3 %32
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  4. Toshiba Satellite L305-S5875 Keyboard Replacement: passo 4, imagem 1 %32
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  5. Toshiba Satellite L305-S5875 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite L305-S5875 Keyboard Replacement: passo 5, imagem 2 %32
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  6. Toshiba Satellite L305-S5875 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Satellite L305-S5875 Keyboard Replacement: passo 6, imagem 2 %32
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  7. Toshiba Satellite L305-S5875 Keyboard Replacement: passo 7, imagem 1 %32
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
Conclusão
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
3 outras pessoas executaram este guia.
Juan
Membro desde: 01/11/13
109 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-5, Maness Winter 2013 Membro de Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
Membros da 4
Autoria de 10 guias
Um comentário
It's not so easy to do step 3.
Texas Chick - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 3,204
