Ir para o conteúdo principal
Toshiba Satellite L305-S5875 Hinge Replacement
O que você precisa
  1. Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: passo 1, imagem 1 %32 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: passo 1, imagem 2 %32 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: passo 1, imagem 3 %32
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  2. Toshiba Satellite L305-S5875 Hinge Replacement: passo 2, imagem 1 %32
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  3. Toshiba Satellite L305-S5875 Hinge Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305-S5875 Hinge Replacement: passo 3, imagem 2 %32
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  4. Toshiba Satellite L305-S5875 Hinge Replacement: passo 4, imagem 1 %32 Toshiba Satellite L305-S5875 Hinge Replacement: passo 4, imagem 2 %32
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  5. Toshiba Satellite L305-S5875 Hinge Replacement: passo 5, imagem 1 %32
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
  6. Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: passo 6, imagem 1 %32 Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: passo 6, imagem 2 %32
    • Close your laptop and flip it over.
    • Remove the 13 screws using a Phillips #00 screwdriver.
  7. Toshiba Satellite L305-S5875 Hinge Replacement: passo 7, imagem 1 %32
    • Gently disconnect the ribbon cable.
    • Gently disconnect the multicolored cable.
  8. Toshiba Satellite L305-S5875 Hinge Replacement: passo 8, imagem 1 %32
    • Gently pull the top case from the bottom case of the laptop.
  9. Toshiba Satellite L305-S5875 Hinge Replacement: passo 9, imagem 1 %32 Toshiba Satellite L305-S5875 Hinge Replacement: passo 9, imagem 2 %32
    • Unscrew the two screws on the hinge. (Be careful to not damage nearby wires)
    • Both hinges shown, but replacing both may not be necessary.
    • Congratulations, you may now remove and replace your hinge!
Conclusão
Uma outra pessoa concluiu este guia.
Tyler
Membro desde: 03/11/14
208 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-1, Calaway Spring 2014 Membro de UMass Dartmouth, Team 3-1, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G1
Membros da 4
Autoria de 6 guias
Um comentário
Will this work for a Toshiba satellite l655 model
ethanhunemuller - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 11
Duração total: 6,530
