Ir para o conteúdo principal
Toshiba Satellite L305-S5875 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite L305-S5875 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305-S5875 Hard Drive Replacement: passo 2, imagem 2 %32 Toshiba Satellite L305-S5875 Hard Drive Replacement: passo 2, imagem 3 %32
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Toshiba Satellite L305-S5875 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Flip the laptop over so that you can see the back. Make sure that the volume scroller is closest to you when it is flipped over.
    • Locate the hard drive compartment. This is in the bottom left hand side of the laptop.
    • Remove the two 5 mm type-0 Phillips head screws that secure the door and save them to a safe location.
    • Remove the hard drive cover.
  4. Toshiba Satellite L305-S5875 Hard Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite L305-S5875 Hard Drive Replacement: passo 4, imagem 2 %32
    • With the small door removed, find the black ribbon that is attached to the hard drive tray.
    • Carefully pull the ribbon to the left so that the hard drive tray slides out neatly.
  5. Toshiba Satellite L305-S5875 Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the four 4.2 mm type-0 Phillips head screws located on the side of the hard drive enclosure.
  6. Toshiba Satellite L305-S5875 Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite L305-S5875 Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove the hard drive from the tray.
    • Make sure that when you slide the tray back into place, that the ribbon remains easily accessible.
Conclusão
David Zhuo
Membro desde: 01/11/13
35 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 20-5, Maness Winter 2013 Membro de Cal Poly, Team 20-5, Maness Winter 2013
CPSU-MANESS-W13S20G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 9
Duração total: 2,412
