Ir para o conteúdo principal
Toshiba Satellite L305-S5875 CCFL Tube Replacement
O que você precisa
  1. Toshiba Satellite L305-S5875 CCFL Tube Replacement, LCD Screen: passo 1, imagem 1 %32
    • Open the laptop so that you can see the screen.
  2. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 2, imagem 1 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 2, imagem 2 %32
    • Remove the four rubber inserts from the four corners of the screen.
    • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
  3. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 3, imagem 1 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 3, imagem 2 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
    • Gently pull the back panel approximately 1 inch away from the screen.
    • Warning: Following step will detach screen from casing. Use caution.
    • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
  4. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 4, imagem 1 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 4, imagem 2 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 4, imagem 3 %32
    • Lay screen down on keyboard.
    • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
    • Carefully remove the ribbon cable by pulling it out of it's socket.
  5. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 5, imagem 1 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 5, imagem 2 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 5, imagem 3 %32
    • At the bottom of the screen, locate the pink and white wires.
    • Unplug the connector from the circuit board by gently pulling it out.
  6. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 6, imagem 1 %32
    • Congratulations, you have just removed your screen!
  7. Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: passo 7, imagem 1 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: passo 7, imagem 2 %32
    • With the screen now removed from the computer, remove the two screws from the screen's metal enclosure.
    • In addition to removing the screws, remove the tape on the edge of the screen.
  8. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 8, imagem 1 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 8, imagem 2 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 8, imagem 3 %32
    • Using a plastic opening tool, unhook the latches on the side of the screen's metal enclosure.
    • Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube.
  9. Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 9, imagem 1 %32 Toshiba Satellite L305-S5875 CCFL Tube Replacement: passo 9, imagem 2 %32
    • With the bad CCFL tube now accessible, very carefully remove it from the screen housing.
    • With the spent CCFL tube now removed, replace it with the new replacement tube in the appropriate slot.
    • Note: Make sure you do not break the CCFL tube, as the contents within the tube are toxic to humans.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler
Membro desde: 03/11/14
208 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 3-1, Calaway Spring 2014 Membro de UMass Dartmouth, Team 3-1, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 565
