Ir para o conteúdo principal
Toshiba Satellite L15W-B1320 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite L15W-B1320 Hard Drive Replacement: passo 2, imagem 2 %32 Toshiba Satellite L15W-B1320 Hard Drive Replacement: passo 2, imagem 3 %32
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
  3. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • The hard drive is connected at the end of the white barcode.
    • To remove, first pull up on the end of the hard drive opposite of the barcode.
  4. Toshiba Satellite L15W-B1320 Hard Drive Replacement: passo 4, imagem 1 %32
    • After pulling up on the hard drive, pull in the opposite of the direction of the white barcode.
Conclusão
Elizabeth Zapata
Membro desde: 09/25/17
190 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 1,295
