Ir para o conteúdo principal
Toshiba Satellite L15W-B1303 Touchpad Board Replacement
O que você precisa
  1. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: passo 1, imagem 1 %32 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: passo 1, imagem 2 %32 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Bottom Panel: passo 1, imagem 3 %32
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: passo 2, imagem 1 %32 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: passo 2, imagem 2 %32 Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Battery: passo 2, imagem 3 %32
    • Lift the battery and remove it from the laptop.
    • The battery's cable connector is still attached to the laptop, so lift the battery out carefully.
    • Disconnect the battery carefully from the port by detaching the connector with a plastic opening tool or a spudger.
  3. Toshiba Satellite L15W-B1303 Touchpad Board Replacement, Touchpad Board: passo 3, imagem 1 %32
    • Remove any pieces of tape securing the board.
    • Using your Phillips #0 screwdriver, remove both screws holding the board in place.
  4. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: passo 4, imagem 1 %32
    • Gently disconnect the cables that link the touchpad board to the rest of the laptop
    • Be careful when doing this. It can be easy to damage the components. If the connector seems stuck, try wiggling it; do not force it off.
  5. Toshiba Satellite L15W-B1303 Touchpad Board Replacement: passo 5, imagem 1 %32
    • Remove the board from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Yanchen Li
Membro desde: 01/22/20
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 290
