Ir para o conteúdo principal
Toshiba Satellite L15W-B1208X Battery Replacement
O que você precisa
  1. Toshiba Satellite L15W-B1208X Battery Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite L15W-B1208X Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn off your laptop before starting.
    • Flip the laptop over so that the model number stickers face the ceiling.
  2. Toshiba Satellite L15W-B1208X Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite L15W-B1208X Battery Replacement: passo 2, imagem 2 %32 Toshiba Satellite L15W-B1208X Battery Replacement: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the ten 5mm screws that secure the bottom cover.
  3. Toshiba Satellite L15W-B1208X Battery Replacement: passo 3, imagem 1 %32 Toshiba Satellite L15W-B1208X Battery Replacement: passo 3, imagem 2 %32 Toshiba Satellite L15W-B1208X Battery Replacement: passo 3, imagem 3 %32
    • Use an opening pick by sliding it in the seam between the bottom casing and the main body of the laptop. Separate the bottom casing from the main body.
    • It is recommended that you start on a corner and work your way along the edge of the cover.
    • Use a plastic opening tool to separate the remainder of the back cover from the laptop.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite L15W-B1208X Battery Replacement: passo 4, imagem 1 %32 Toshiba Satellite L15W-B1208X Battery Replacement: passo 4, imagem 2 %32 Toshiba Satellite L15W-B1208X Battery Replacement: passo 4, imagem 3 %32
    • Disconnect the battery from the motherboard by gently pulling on wiring connecting to the motherboard.
    • Carefully lift the battery out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 34
Duração total: 514
