Ir para o conteúdo principal
Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement
O que você precisa
  1. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement, Battery: passo 1, imagem 2 %32
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement: passo 2, imagem 1 %32
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement, Bottom Case: passo 3, imagem 1 %32
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement: passo 4, imagem 1 %32
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement: passo 6, imagem 1 %32
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement, Fan/Heatsink: passo 7, imagem 1 %32
    • Remove the four 2mm screws with a Phillips #0 screwdriver.
    • Remove the two 2mm screws with a Phillips #0 screwdriver.
  8. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement: passo 8, imagem 1 %32
    • Use a spudger or your fingers to disconnect the fan from the motherboard.
    • Remove the fan and heatsink.
Conclusão
Joshua Swanson
Membro desde: 02/20/17
701 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S2-G2, Sullivan Spring 2017 Membro de USF Tampa, Team S2-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G2
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 361
