Ir para o conteúdo principal
Toshiba Satellite E45t-B4204 Thermal Paste Replacement
O que você precisa
  1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: passo 1, imagem 1 %32 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: passo 1, imagem 2 %32 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: passo 1, imagem 3 %32
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: passo 2, imagem 1 %32 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: passo 2, imagem 2 %32
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: passo 3, imagem 1 %32 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: passo 3, imagem 2 %32 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: passo 3, imagem 3 %32
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: passo 4, imagem 1 %32 Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: passo 4, imagem 2 %32
    • Locate and remove the four 3 mm screws around the CPU.
    • The CPU is located beneath the copper heatsink.
  5. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: passo 5, imagem 1 %32 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: passo 5, imagem 2 %32
    • Carefully remove the heatsink from the rest of the motherboard and casing.
  6. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: passo 6, imagem 1 %32 Toshiba Satellite E45t-B4204 Thermal Paste Replacement: passo 6, imagem 2 %32
    • Now that the heatsink has been removed the CPU is visible. The CPU is the green square with silver metal in the center.
    • Reapply thermal paste above the CPU.
Conclusão
Eduardo
Membro desde: 03/22/18
411 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 517
